hub assy question.
    hub assy question.
    Is my 91 dx hub assy pressed on? Or bolted on?
    Also, will any cb7 hub assy fit my 2dr dx?
    .....................EJ1..........................................Turbo CB7.....................
    91 Accord Turbo DX
    93 Accord LX
    90 Accord LX
    02 Grand Am GT
    06 Turbo 2.4 G6
    both...
    the hub is bolted and somewhat a press fit. you can still bang it off.
      So I won't need any special tools?
      91 Accord Turbo DX
      93 Accord LX
      90 Accord LX
      02 Grand Am GT
      06 Turbo 2.4 G6
        you can either use a fixture with a slide hammer and pull from the outside or find longer bolts to thread into the back and bang it out with a hammer.
        or...take the entire knuckle out the car and use a hydraulic press but ive always done it the top two methods.
          Are all cb7 hubs the same?
          91 Accord Turbo DX
          93 Accord LX
          90 Accord LX
          02 Grand Am GT
          06 Turbo 2.4 G6
            yes
              Figured I'd bump this old thread instead of making a new one.
              Does anyone know what the size of the bolt and threading is to thread in and bang the hub/rotor out of the knuckle?
                I think its an M8-1.25?
                  Thanks
                    watch this video it shows u how to do them. http://www.youtube.com/watch?v=FEDri...layer_embedded
                      M12-1.25 is the studs for the wheel
                      the 4 bolts on the reverse side are 10mm 12 point heads, you can get them new from Honda. better to have the hub professionally pressed into the new bearing. while you are there might as well do the lower ball joints.
                        our studs are M12-1.5 for the lug nuts
