can someone help me please?
    is the wire harness on the cb7 similar to the cd5 harness? If i put that motor in do i need the vtec harness from the cd5? will it wire up with my dash harness so everything can work right? can any body help me out please.
    They are not the same, but you can use the CB7 harness. You just have to add a few wires (and do a few more things if your new motor is from a 96 or 97). The wiring is similar to that of the H22 swap.
    One question... why are you swapping in this motor? Please tell me it's because you blew your F22A and you found a cheap replacement... and that you're not pulling a perfectly good F22A for this "upgrade"
    Also, descriptive thread titles will get you more responses. EVERYONE that posts on here needs help. Saying what you need help with will actually get people to open the thread and give you that help.
