check the wiring but it might just be a short somewhere in the vtec harness... and the system supply... cant that be because of a fuel filter. weak pump. stuff like that. ive never had a car pop that code i dont think but in school they reminded us of fuel filters or a weak pump for this issue... the map sensor will make it run like shit too.. and if your throwing a code for that and he isnt its obviously different problems...
H22 running really horrible
Originally posted by d112crzy View PostSo do you know if you put deisel in it, if so how? How the hell do you end up putting deisel in your car?
The 21 and 22 are coming on because your vtec wiring is wrong/faulty.
Some how (don't know where it came from or how it got in there) a small washer fell out of the timing cover after I pulled it off. The belts and everything looked fine but the crank was off by like 4-5 teeth, and the washer was all chewed up. We took all the belts off and looked but can't find anywhere that looked like a washer and maybe a bolt might be missing. So we put the belts on and the valve cover and did a quick start to make sure it ran and it started right up. We just didn't think that is was a timing issue since the car was running fine one moment then bad the next. I'm all baffled to where it came from but thank god the crank didn't slip any more.
Thanks to all the people that wrote in giving me things to look at and try.
You might be running on only 2 or 3 cylinders, yeah I agree with SleeperSedan too, check that timing. I was thinking maybe you have a clogged throttle body, not having enough air go through.
new $10 purple/yellow tint fog lights
H22a Sleeper:
http://www.cb7tuner.com/vbb/showthread.php?t=124470
Originally posted by JDM_H22_SLEEPER View PostYou might be running on only 2 or 3 cylinders, yeah I agree with SleeperSedan too, check that timing. I was thinking maybe you have a clogged throttle body, not having enough air go through.
