I need some help with a engine problem. I have a stock H22a with a auto lsd. Problem I'm having is the engine is coughing and sputtering a little at low rpm's and a lot when trying to rev it up. It's very difficult to get it above 3k. It has almost no power to drive. It must be running super rich cause it's spitting out lots of black crap. It was throwing a cel code of 21 & 43. Then after trying to diagnose the problems the cel code of 22 & 43 came on. I didn't do anything to vtec so I don't know why the codes changed. The codes don't come on till the car is at running temp. I pulled the plugs and they are black and powerdy. I assume it's unburned gas, and that there was a electrical problem. I changed out the cap and rotor first thinking they might have gone bad, that didn't work. I then changed out the distributor and still no better. I tried changing out the ECU and that didn't do anything. I checked all the wires and sensors that I can see and nothing looks bad. It then seemed that I might have some bad gas or diesel in the tank, so drained that and added fresh gas. Still same problem. I checked the compression on all 4 cylinders and it was between 272-276. I read on here that this is probably high but it's a least consistent. I might have left a few things out, but here is the jest of it. Looking for any help. Please go ahead and ask whatever other questions you might have. I am out of ideas with this and need help.
Thanks
Thanks
