temp gauge
    temp gauge
    driving home from class tonight and my temp gauge flings down to the ice cold section. go to turn on heat and ice cold air. then my temp gauge would slowly rise then slowly drop again. check rad and rad lines no visible leaks and rad still was full of anti freeze. my thermostat was replaced a lil more then a moth ago. what could this be?
      The thermostat is probably bad....again.
      "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
        OEM Honda thermostat?
          I agree. I had this same problem last week. Changed the thermostat and the problem disappeared
          93 ex coupe
          http://www.cb7tuner.com/vbb/showthread.php?t=164698
            i think it was a denso. my original wasent even bad i just was trying to get heat out of my car and i thought i would replace that since i drained all the lines and rad and cleaned out my heater core. so its my thermostat? this one just took a shit on me?
              It's probably in backwards. Save yourself some trouble in the future: If it ain't broke, don't fix it.
                hahaha dude its not in backwards.
                  You sure? People do put them in backwards, including professional technicians.
                    hmm idk i took the one out and put the other one in exact to the way i took it out. but i guess there could be a possibility if they look the same all the way around
                      Also when you do replace it, make sure the system is bled properly and free of Air Bubbles.
                        Or if the person who put the first one in did it wrong.
                        How cold was it outside?
                        ____
                          its like 15 degrees. when i put the new one in i drained my rad and all my coolant and flushed my heater core out cause i had an air bubble somewhere and had no heat. then put everything back and had heat for about a month now. then this happens. but today my temp gauge was working but still no heat. it would be a blast of heat then dissapate to cold air. im thinkin its my heater core
