I was wondering i have a 93 accord tenth aniversary have the 15 inch stock wheels on it but would like aftermarket rims but i really dont like the roller skate look. So i was thinking of buying a set of 15 inch aftermarket wheels and that way i could lower it and not have tire rub issues and still be able to afford tires. What is the real advantage to bigger rims better handeling but dont they have a tendancy to slow you down? I dont know I am just wondring what are your thought guys.
what rim size is the best
Originally posted by jeramey513 View PostI was wondering i have a 93 accord tenth aniversary have the 15 inch stock wheels on it but would like aftermarket rims but i really dont like the roller skate look. So i was thinking of buying a set of 15 inch aftermarket wheels and that way i could lower it and not have tire rub issues and still be able to afford tires. What is the real advantage to bigger rims better handeling but dont they have a tendancy to slow you down? I dont know I am just wondring what are your thought guys.
16" is generally regarded as the best size for handling and looks. 15" aftermarket rims often look small, unless you go for an oldschool look. 16" tires aren't much cheaper than 17", though... so if tire price is a major concern, smaller is better.
Rubbing issues are due more to offset and width than diameter. The overall diameter of the wheel and tire should remain the same regardless of rim size. If you don't want to rub, be sure to get a proper offset, and wheels that aren't crazy wide. Offset around 42, and a width of 7" or less works well. I have 42 offset and 7.5", lowered a little over 2". I've had some rubbing on the splash guards in my wheel wells.
I have 15" wheels, altho I would like to drop it soon. They're aftermarket, not the best ones out there, but I got them with a tire/wheel combo package. So I'm stuck with these until I can afford to get better ones
My CB7:
http://www.cb7tuner.com/vbb/showthread.php?t=124470
new $10 purple/yellow tint fog lights
H22a Sleeper:
