Sunroof Cover Stuck Open
    Sunroof works fine, the cover is stuck in an apparent locked (feel it) position, any ideas. Yes I know I can drop the headliner (to get a closer look), I thought that I could "unlocked" it somehow. FYI the car was purchased recently so I dont know how it got this way. Thanks
    You just have to pull the hell out of it...
    the same thing happened to mine...
      sometimes the wiring harnest on the switch can be loose...........ive had the problem before and i thought i was the sunroof
        Nah man... he is talking about the sunshade that is under the sunroof glass...
          thanks guys, FYI funny thing happened at the pick-a-part today I checked 2-3 working CB7 sunshades and lightly "slammed" them open and they did "lock" like mine has, oops... I commute 106 miles a day roundtrip (VC to Hollywood) and it can get a little hot...UPDATE...Removed sunroof assy no-go couldnt access cover, ended up dropping headliner and dropping entire sunroof assy (needed 2 ppl) to access sunroof cover rail from back. It was a F&%$# little tab clip that had sprung open in the last section of rail where there is an opening for a the "soft-lock" of the sunshade.
