I noticed the other day that when my dad was leaving for work he accelerated a lil bit and this black/greyish colored smoke was coming out the exhaust. The weather was normal, not cold, and I just got home from a drive. I did hit vtec on the drive back home on the FWY. The smoke didn't smell like gasoline, smelled more like oil, burning oil. The smoke wasn't thick, it was rather brief and went away. What's the main problem? Is the car burning too much oil?
black/greyish smoke coming out of tailpipe.
new $10 purple/yellow tint fog lights
H22a Sleeper:
http://www.cb7tuner.com/vbb/showthread.php?t=124470Tags: None
I assume you have an H22... it helps a LOT to tell people what you have in your car, and what is done to it.
Black smoke is fuel. You're running rich. If you're running a stock P13 ECU, that's very common, especially with added mods like an intake and exhaust.
Aside from getting a custom tune, the best thing to do is to do a full tuneup. Spark plugs, cap, rotor...
Originally posted by deevergote. View PostI assume you have an H22... it helps a LOT to tell people what you have in your car, and what is done to it.
H22a Sleeper:
Originally posted by BLUBB2 View PostWell its better to run rich than lean,Ill tell you that.lol
Everybody else is right though cap,rotor,spark plugs and wires.
Also quite possibly 02 sensor and check igntion timing.
H22a Sleeper:
The problem isn't probably that big of deal if you are treating it as a small one. If could be valve seals leaking a little oil. Could be your mufflers are filled with shit and some times you are seeing it burn off... could be a bunch of things. Monitor your oil and check it at the end of each day. If its not burning a bunch your fine. They are revving high and being beaten on they will be hurting. If you drive it normal it won't be hurting. Its mostly in how you treat it also...
Superior Tuning Solutions
Dedspool MFG
1995 Civic Coupe : A/M F swap
LOCK.IT.UP
