Bigger injectors?
    Bigger injectors?
    Question:
    If you are not running boost...would bigger injectors benefit you any at all on a H22 setup?
    Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
    ...Zex wet kit, 65 shot, dual purge, JDM H22...pure sex! .....I owned 8 CB7's in one year...top that JARHEAD...lol
    ...this thread has been graced by the new CB7 King
    Originally posted by 90-JDMCB7 View Post
    Question:
    depends what has been done to the motor. probably no need unless you are running some pretty high numbers in terms of power, 220whp+.
    JDM h22a's come with 340CC injectors. thats a lot of fuel.
    USDM injectors push a bit less. about 290cc i think. i may be wrong.
    Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
      putting bigger injectors will make the car run rich, and you'll loose hp
      miss my turbo cb7
        All OBD1 h22's came with low impedance 345cc injectors, obd2 came with high impedance 290cc injectors.
        Only if you're untuned. I run 450cc injectors with my setup, but only because I got them for free.
          More fuel does not equal more power. More airflow equals more power (to put it very generally)... and more airflow demands more fuel for proper combustion. If you can stuff more air in there, bigger injectors will work. Otherwise, they'll do nothing for you.
            Yea I Would Leave Them The Same
              Thanks guys....it all makes sense now....thanks Mike...the way you broke it down makes it seem more simple
