Windshield Washer
    Windshield Washer
    hey whats up?
    i have a problem. my windshiel washer fluid its frozen. lol
    bks before a move to iowa i put new, but i didnt now that i have to put the one that dosent froze. lol
    any idea on how to remove the one that its frozen?
    heat gun get under your car and point it AT A DISTANCE at your resivior? till it melts anough to run it all out of the line. you might even beable to take a long ride, and before you turn the car off check to see if it melted from the engine bay heat.
    just a sugestion...not a def fix.
    _____________________________
    91 Accord F22B
      ^^^haha... what you want to do is keep a bottle of windex in your car and whenever you got salt on your window lean your head out the window and spray the windshield... then give a blast with the wipers
        Maybe try going to a car wash that steams the underside of your car? Might get warm enough to melt your fluid, and you get a clean car. You could try pouring some of the nonfreeze washer fluid in, as well.
        To remove it, you have to remove the bumper to get to the tank.
        1992 Prelude S w/swapped H22A
          so i alredy melted half of the resivior.
          now i have new problem the wipers stop workin. lol
          i check the fuse and its ok
          what else can check now?
            Are they frozen to the glass? If it's cold enough to freeze the fluid, it is a possibility.
              It's possible you've burnt out a relay, but I don't know which one is the wiper motor relay. Does it sound like they're trying to work? If the car is ff, the key is on so they should work, what do you hear happening when you turn them on?
                Nothing there is total silence, the blades dont work or the fluid runs. no soudn of it trying to work either.
                  check all your fuses... It may be as simple as you popped one...
                    X2, recheck your fuses, then check the relay (Sorry I don't know which relay it is off the top of my head, seems like it should be marked and probably in the fuse box under the hood.) just switch it with another one in the car with the same numbers and diagram on it. If they work, switch it back and go get a new one from the JY or parts store.
                      so after so many horas working in her mi bro found that the conection on the sterring colum were lose. lol
                      it was something so simple
