misfire AGAIN!!!!!
    misfire AGAIN!!!!!
    Alright, F22a1, #3 is dead. it has new plugs,wires.cap, disty, and I just put a new injector in it. it runs, but rough, when I unplug the plug wire nothing changes. BUT IT DOES HAVE SPARK!!!!! Then with it still running, I unplug the new injector, and STILL NOTHING!!!!!!
    Now where do I go next???? My only other guess is the injector isnt getting power. any Ideas??????? HELP I LOVE MY CAR!!!!!!!!
    Why dont you comfirm that? Try the ol skool method where you stick a screwdriver(or stethoscope) to the injector and listen to see if its operating. You can also invest in a noid light to check the wiring connector. You can also check the resistance on the connection terminals of the new injector and see if its within spec.
      alright I have narrowed it down to this. There is no power to the injector. Any ideas????? PLLLLLEEEEAAAAASSSSEEEEE
        So the wiring is bad? Check the wiring for continuity between the resistor box and injector connector. Also check the connections/wiring between the injectors and ecu.
