My gyrls 92 lx was running hot. Radiator was leaking so replaced it and t-stat. Now car still runs hot and upper hose swells. Replace upper, heater, & bypass hose. Ran ok for a lil bit, but still got hot. Can it be my water pump? Now got a new symptom. Car sputters when i start. 15 sec. then idles fine. White smoke out the tail. Can the Headgasket be gone? Gonna try a compression test soon. Also, oil light came on. I Got oil. Hope it is not oil pump.
overheating! headgasket gone?
Originally posted by dano28 View PostNot sure about the rest, but, water pumps pump coolant as long as they are turning. What makes a bad water pump is leaking.
Seems like your engine's building pressure. Mine did the same, and was so bad it'd squirt out of my cap with it fully closed. I kept driving it like a moron, and had to replace the entire engine.
thermostat, definitely waterpump, and timing belts. Oil pump, ehhhh. Really isn't a MUST, but if you have the extra cash and have the time to replace it, go for it man. I'm one to replace things I know haven't ever been replaced on the car. Suchas me being in the works of replacing a heater core. Oh man is it a pain in the ass. haha
Oh, and while you have the head off, replace your spark plug tube seals!! Take you 2 minutes with the head disassembled.98' Mustang 3V Swap
11' VW CC R36
Originally posted by rollinjoy View PostMy gyrls 92 lx was running hot. Radiator was leaking so replaced it and t-stat. Now car still runs hot and upper hose swells. Replace upper, heater, & bypass hose. Ran ok for a lil bit, but still got hot. Can it be my water pump? Now got a new symptom. Car sputters when i start. 15 sec. then idles fine. White smoke out the tail. Can the Headgasket be gone? Gonna try a compression test soon. Also, oil light came on. I Got oil. Hope it is not oil pump.
Also are you losing coolant? do you constantly have to fill coolant in the rad. or overflow? What's happening is its leaking into your combustion chamber when the car is off, and when you go to start it, it burns the coolant off, thus causing the stuttering for the first 15 sec.
The HG itself was about 75 from Majestic, then I got a 3 angle valve job for 300, ARP headstuds for 135, Bisimoto IM gasket for 57 and then the rest prob. 50 for coolant, and oil/filter.
But all you'd need is 75 for the HG and maybe about 50 for the milling of the head...if you're head is in good shape. I had everything done on my cyl. head though, so that's why it cost so much. But now's a good time to do the timing belt if its close to replacement. Since you prob. will have to wait at least a day or two for the machine shop to get the work done. I had to wait 3 since my work was more extensive. But my belts and pump were done like 10k ago, so i didn't do em. Its all up to you what you want to do in the end though.Last edited by Losiracer2; 01-29-2009, 01:35 AM.
Originally posted by Professor View Postsounds like your headgasket...make sure you burp the system correctly.
just thought i would add
92accord coupe-260 000kms timing belt wp and all seals and belts changed at 245 000 due to maintenance schedule, not failure.
just lost the headgasket idling in traffic to work. the car overheated 4 days ago and recieved and new rad, themostat and cap. i thought it would fix it due to the original rad & cap aswell as the thermostat did look terribly corroded and the rubber looked like crap ( swelled up from oil/ fuel i assume). well not so lucky . the head gasket finally gone and is allowing major coolant too the cylinders.96 Accord SiR driveline installed. CF2 donar
