In trying to change the axles, I broke my beloved 1/2" breaker bar. I had a friend come over and he broke a breaker bar and a 1/2" drive ratchet. He had an electric impact, but that didn't work. That axle nut is tighter than hell. Anyone ever cut off an axle nut before? I can't get the car to work to have someone with an airgun hit it. Anyone have any other 'at home' remedies?
axle nut, part MXLCVIII
yup i had to to that when i first bought my coupe lol, except i didnt car about the wheel so that helped alot
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Not so DD 2013 Subaru Impreza WRX STI
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
Originally posted by wed3k View Postget a real impact. takes it right off.
PSN ID's:Tidashoni
My FS Thread
Originally posted by almostJDM View Postnot just a real impact but a big air-compressor
Originally posted by Gotenks64 View PostThis is what you do, get a GOOD breaker bar either maded by Craftsman or Snap-on or some company like that. Then get a steel pipe and use that to torque it off. I did the auto to manuel swap on my car this weekend and that worked like a charm...
Originally posted by visualpoet View PostYeah, you got lucky. I snapped a brand new Craftsman 1/2" breaker like this.
x2.. plus another breaker bar and a bent 4ft. steel pipe..
to the OP; seems like your axels are still original factory.
since i know the full history of my CB. i had no prob taking off the driver side since i had it replaced before in a shop. the passenger side i know was never replaced since it rolled of the dealership. thus, 2 broken breaker bars and a bent pipe.. hell! hulk hogan can't even break that nut!
this solved the prob in 2mins..
Originally posted by jdm_inspired View PostUse PB blaster and a 4ft pole on the breaker bar. Oh dont forget you need to step on the bar but be careful not to fall. Works for me all the time.
I do wish I'd had this wheel:
All I could find when I went looking was a 20 pack of these (I checked Lowes and Walmart before giving in):
It took all 20 of them to do both sidesLast edited by visualpoet; 01-27-2009, 09:20 AM.
Originally posted by visualpoet View PostI used wd-40, pb blaster, mapp gas, a 40 inch cheater pipe (which bent into a lovely curve before the knuckle snapped off of my breaker) and even tried letting it set overnight soaking in pb blaster.
as for being original, the nuts are 36mm and i thought those only came with aftermarket axles. the replacement nuts i got from work are 32s.
