Valve Cover Gasket??
    Hey I'm no nubie at working at cars or anything but I am kinda new to the Honda sceen so I got kinda a stupid question...Neways!!!
    What are the little O-Ring Gaskets for that come with with the Felpro Valve cover gasket kit... The reason im asking is I installed the Valve Cover with out them and It started leaking so I ripped it off and bought a hole new kit...
    I did install the Flat plug gaskets and the Outer Cover seal but left the small O-Rings out...I couldn't figure out where the go..
    Do they go under the flat ones or what???
    The kit comes with 3 different hgaskets... Cover Gasket It's self, flat spark plug gaskets and the O-Ring Gaskets??
    Sorry for the Dumb Question but I just dont want to wast another gasket kit....
    Thanks
    1990 Accord LX Sedan~Sold
    1993 Accord EX Sedan~Sold
    1995 Suzuki GSX-R 750~Totaled
    Plenty of people have wondered this. Me being 1, but the o-rings are for your spark plug tube seals. That's a whole 'nother project. They're to be used if you're gettin' oil into your spark plug slots, you gotta take your rocker arm assembly off to get to 'em. You could keep them just incase you have a future run in with the oil in the plugs. I plan on replacing the tube seals here once it gets warm, just for kicks.
    98' Mustang 3V Swap
    11' VW CC R36
      If you scroll down on this link to #5-6-7-8, you'll see exactly where they go.
      http://www.cb7tuner.com/vbb/showthre...e+seals&page=2
      98' Mustang 3V Swap
      11' VW CC R36
        I'm getting Mad Oil In My Tubes!!!! Fuck!! So What all Do I Need To Do To Install Them???
          That link above, is the DIY on replacing them. Everything you need to know.
          98' Mustang 3V Swap
          11' VW CC R36
            I'm starting to really hate my project at the Min...
              Thanks for the link!!!
                Welcome, hey..I haven't had anything but problems with mine and I've had it 2 years. It becomes a hobby real quick. Most of these problems you can fix yourself with the help of this forum, without having to spend massive amounts of money to get a mechanic to do it. The only big thing about replacing the tube seals, is the type of wrench you need, since you have certain torque specs for the bolts. Other than that, it's cake.
                Just wait until you start wantin' more power. There's plenty of things to keep you occupied then.
                98' Mustang 3V Swap
                11' VW CC R36
                  Just curious....I have oil leaking (slowly) out of the top left bolt on the top of my valve cover...what is this and how to fix?
                  Bought from: TypeG,mak,CB7_ACCORD,ChampCoupe,Blackex
                  Traded with: Cb7xChun
                  Sold to: Rob_is_legend,DaddyO,daheavyking
                  Sedan MR Thread Coupe MR Thread Prelude Si MR Thread
                  My huge For Sale Thread
                    Yea If I ever get into a job that to big I just go see me Dad hes a ASE Master Tech with his own shop...LOL
                    I've been working on cars my whole life so I will pretty much try anything once...
                      i had the same prob. i had to get new tube seal but didnt they didnt work to well, so i took them out and put some copper sealant on them and i havent have any probs that was a year ago
                        Have a tech at a parts store (autozone ect.) look for #9 on this.
                        Than remove the nuts, replace those small seals, and put the nuts back on. Dont tighten the nuts very much, as they break easily...
                          is it bad if u broke the nut that holds that one wire on the valve cover on the right side on the front and wat is that for anyways is it a ground wire. hit me up thanks
                          P.NO president of mixed breeded family car club.
                            Its a ground you need to fix it....You need all you grounds atached!!
