I got a cb7 m/t, my idle is way to high and is causing it to hiccup, currently i'm running w/o my IACV to keep steady, I changed the IACV and the fast idle and still having the same issue, i took off hte whole plenum and cleaned everything with TB cleaner, cleaned TB IACV, Fast idle adjusted the fast idle and checked for vacuum leaks, and also closed completely the valve in the TB..... What else could it be?
Tired of the high idle
Originally posted by paulhenrick2k8 View Posti think i have the same problem too when my engine is cold. but its surging from 1500 rpm- 2000 rpm.R.I.P Rex 10/10/97-08/06/09
There aren’t enough words in this world to say how much you will be missed. love you buddy!
Originally posted by flcb7 View PostYeah mine dose the same thing when cold, but mine will do it from like 500rpm - 2200rpm. It SOMETIMES can be caused by not changing your oil. I think thats why mine is acting up. Im 400milles over dew on my change. Also happens yo my buddy’s h23 vtec his motor tells him by how it idles when he needs to chance his oil...it's kinda weird.
