watsup cb7, i got a quick question.. i was looking at my dashboard nd saw the "brake lamp" sign was lit. What does that mean?? My brake lights are perfectly fine nd theres nothing wrong wit my brakes.. Ne ideas?
Brake lamp?
Aftermarket Tails??
In case any of those ^^^^ are not the issue, a quick question. Do you happen to have aftermarket taillights? I know when I switched mine on my '93, that light came right on the first time I tested the lights. It stayed on until I just ripped out the cluster (not literally) and took out the bulb for it. Peace.
Originally posted by 91Accord-LX View PostMight want to check all the wiring as well.
EDIT: I had to re-wire my passenger side tail light because the last owner's son hacked the shit out of it and rigged it all wrong.
Originally posted by TeamAccord View PostIn case any of those ^^^^ are not the issue, a quick question. Do you happen to have aftermarket taillights? I know when I switched mine on my '93, that light came right on the first time I tested the lights. It stayed on until I just ripped out the cluster (not literally) and took out the bulb for it. Peace.
first get someone to stand behind you and make sure your REVERSE lights come on, your brake lights and your turn signals. if you have a problem with these, its a wiring issue. there is a accuator that is connected to the brake peddle that runs the taillights, could be bad. do some more diag to your car. use a multi meter and check all the goods continuity, resistance. got continuity and 0 resistances? not your wires.
the thing is, people will have a answer for how to rig it to go away but not to fix it. i have a manual, that ive read front to back and can provide the flow chart for you to fix your problem if its actually that much of a headache. if not rig it up and leave it like that._____________________________
91 Accord F22B
