I am trying to figure out how much power stock f22 pistons and rods can take. I do have arp rod bolts already for my motor along with head studs. What kinda of psi on say a t3/t4 super 60. I do have a legit good tuner to go to too. So what am I looking at with:
F22a1 with a6 cam, h23 intake mani/throttle body, arp stuff, and a mls head gasket. Motor is healthy as well.
I used this turbo on my old civic set up on a built bottom end d16z6. I made close to 250 whp on 15 pounds on a safe tune. Though I didn't get full boost till the end of second gear lol.
info on turbo:
Compressor Specs :
3" Compressor Inlet
2" Outlet
6 Blade Wheel
76.15mm Major
58mm Minor
Compressor .50 A.R.
T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Turbine
70.80mm Major
61.90mm Minor
Turbine .63 A.R.
info on turbo:
Compressor Specs :
3" Compressor Inlet
2" Outlet
6 Blade Wheel
76.15mm Major
58mm Minor
Compressor .50 A.R.
Turbine Specs :
T3 Type Turbine
11 Blade Turbine
70.80mm Major
61.90mm Minor
Turbine .63 A.R.
