from what year prelude si can i get an h23 intake manifold for my f22a1?
h23 intake manifold
They are the same, but while your at it you can get one of these. http://bisimoto.net/store/index.php?...roducts_id=129
"The Turtle"
DD/Trail Rig/Mud Bug
Should be none. The only thing is if you have an A1 or A4 you have to hook up the IAB's. If you have an A6 just replace and hook everything back up. All the sensors are the same, you don't have to change any unless they are broken/defective. Usually for the ones who have the A1 or A4 ethier hook it up to vacumm, gut it, or hook it up with an ECU that controls them.
"The Turtle"
Originally posted by 93F22A6 View PostShould be none. The only thing is if you have an A1 or A4 you have to hook up the IAB's. If you have an A6 just replace and hook everything back up. All the sensors are the same, you don't have to change any unless they are broken/defective. Usually for the ones who have the A1 or A4 ethier hook it up to vacumm, gut it, or hook it up with an ECU that controls them.
Here this will help. http://www.cb7tuner.com/vbb/showthread.php?t=16242 Just read through and follow intructions and after your done you can enjoy yur work.
"The Turtle"
Originally posted by JDMchristian991 View PostCan you show a picture of which vacuum line you hook it too?Thats the only thing stopping me from installing mine..
"The Turtle"
