I am going to be rebuilding my F22A1 engine in a few weeks and im doing research on how to get somemore horsepower but still be smog legal in california. I know Bisimoto's stage 1 cam is smog legal but are there any others out there that are? I know Bisi is the best but im just wondering. Another question i have is if i got my head P&P and left the stock cam in would i gain power? Also would boring it .030 over make any more power then standard bore? I already have a cheapy intake, headers, and a muffler (stock piping and stock cat) i am going to be putting 2.5" piping after the rebuild and maybe a high flow cat.
F22A1 performance rebuild questions
id stick with the camshaft upgrade...boring out should only be done to straighten and true the bores.
a port and polish on a stock head most likely wouldnt do anything unless the exhaust side was opened up and accompanied with proper bolt ons. a lot of times, porters will open the ports too much and wont create enough air velocity and the motor will just be a pig.
you can also lighten up your rotating mass a bit however touching the crank and rods is not recommended unless it is a real performance motor. you can add an ATI or fluidampr crankshaft dampener and a lighten flywheel.
you can mill the head about .020 or .030 and this will bump your compression about a quarter of a point (whopp-dee-doo right?)
however general rule of thumb is 15 hp gain per point of compression.
So just a basic valve job with a cam and mill the head? As far as the bottom end goes wouldn't the glaze need to be taken off the cylinder walls for the new rings to seat properly? Where im going with that is if the block needs to be taken to a machine shop for that and the .030 over pistons are the same price as standard would .030 over do SOMETHING? lol.
Originally posted by 91lxf22a1 View PostSo just a basic valve job with a cam and mill the head? As far as the bottom end goes wouldn't the glaze need to be taken off the cylinder walls for the new rings to seat properly? Where im going with that is if the block needs to be taken to a machine shop for that and the .030 over pistons are the same price as standard would .030 over do SOMETHING? lol.
.020 should clean up just fine.
if you can, get a performance vlave job and backcut the valves. the machine shop would know this.
also deburr the pistons, take any sharp edges away that could potentially impede flow and/or create hot spots.
Originally posted by 91lxf22a1 View PostI already have a cheapy intake, headers, and a muffler (stock piping and stock cat) i am going to be putting 2.5" piping after the rebuild and maybe a high flow cat.
I would add the Bisimoto level 1 camshaft to your plans, the H23 intake manifold & H23 throttle body combo as well or F22a6 intake manifold/TB setup. If you still have money, I would have the exhaust ports on your F22ax head ported, if on a budget, this is the better bang for the buck on a budget build.
CHR Motorsports (www.chrracingproducts.com) will clean, port your exhaust ports, resurface your head, new valve seals and 3-angle valve job for $660. Check them out, talk to Jeff, real nice & honest guy.
More info in link below:
http://www.cb7tuner.com/vbb/showthread.php?t=119746
Originally posted by 91lxf22a1 View PostWould the intake manifold swaps be smog legal?1992 Prelude S w/swapped H22A
If you have a F22a1, here's a list of things to do to make 30+ hp for AT MOST $500.
http://www.cb7tuner.com/vbb/showthread.php?t=88154
You can get all those parts from the JY.
