H22 swap first start
    I just finished with my h22 engine swap, but i got a problem when i start the engine it will start but stops right away, i tried to press gas but nothing, i dont know if its because i didnt replace the F22 fuel pump,or due to gas octane,,,,,any ideas ?
    When i did mine the sock on my pump decided to turn to crap, but that was just me. The f22 pump will work with h22. Thats not an issue unless you were having problems to begin with.
      Have you checked all your wiring?? Like ground or anything else... 'cause if it's starts it means that you have gas but your fuel pump cut off right away....
        sounds like a fuel pump relay.. or a bad fuel pump, try turn'n the key on but dont crank it.. you should be able to hear if your fuel pump is turn'n on if nothing, check the relay, if relay is good check fuel pump.. good luck!
          Have you checked your timing?
          1992 Prelude S w/swapped H22A
            i tried it and i can hear the fuel pump on, what are the chances that can be the distributor? because my H22 came with internal coil, so i just made some adjustments to make it external, some other people told to check the vacuum connections,, i dont know is kinda complicated,,,,,,,but the good thing is at least crank and start but doesn't stay on,,,,
              ohh one more thing i just checked the spark plugs and all 4 are dark, with a strong gas odor ,,,,,,it will b due to weak ignition,or too lean condition ,,,right?
              so maybe the distributor is bad or the fuel system
