noise while driving
    noise while driving
    okay i heard this weird noise coming from the engine while driving. sounds like air and squeking. i dont know how to explain. have anyone have any idea what the problem could be? it's a '93 accord lx with 287.6 miles on it. all stock.
    "Sounds like air and squeaking".
    Nope, not a clue with that description.
    The "squeaking" could be your front suspension.
      thanks for the reply man. but its not the suspension. the noise is coming from the engine. first time i heard it and i heard it like 4 times this morning. the weather is below 20 degrees for sure.
        I think you should inspect around all of your air hoses. You stated it sounds like air so check all of your vacuum hoses.
          Can you narrow down where this noise is coming from in the engine bay? Anymore observations made on this issue?
          By "air sound", you mean like a rushing air sound or vacuum leak? When does it occur (engine RPM, vehicle speed, still happen in neutral, etc.)? When does this squeak sound occur? Is the squeak a one time ordeal or constant?
          Be more specific or people can not help and if they try, it will be very vague and more than likely not help. Ball is in YOUR court man.
            yeah maybe i'll do that.
              ok, i'll try..
              sound is more likely squeaking than air. it happened while i'm just driving norman, prolly like 40 mph so i was in the 4th gear that time. i dont know where exactly it came form coz when i opened the hood the time u pulled over, it didnt make any sound. if im going to answer your last question, i'll say 1 time ordeal coz its not permanent. thanks for help.
                The following info might not help as it may have nothing to do with your situation...my f22a1 have a "wirr" at around 2000-2500, hard to hear unless you have iron solid motor mounts...as I do...nothing to worry about.
                Also when my engine is around 1500...maybe 2000 (sorry I don't pay attention) the intake hums...high end hum...and most noticeable in cold weather during warm up...but that is because I do not have an intake resonator anymore.
                Make note of rpm, gear, speed (course we can est. speed from rpm and gear), engine temp, weather conditions...and as best you can description of sound(s). If it doesn't happen again then forget about it. If it happens enough for your to take those notes, then there may be something to figure out.
                ____
