Guages Help!!
    Guages Help!!
    anyone know how to hook up the air/fuel and oil pressure and rich/lean guages on the car..i got them with the car but their unhooked and would like to know how to d o it
    The oil pressure gauge taps into the oil pressure sending unit circuit and the air/fuel ratio gauge (which should tell you if there is a rich or lean mix) taps into the O2 sensor circuit. How do you know these gauges are calibrated to correctly read these measurements?
    "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
