Trunk Wires
    Trunk Wires
    I accidentally touched one of the wires to the lights on the trunk lid to ground and now the whole gauge panel and is like dead and i cant take it out of park. I checked the fuses and the only one i saw was fried was the "horn stop" one. it seems weird if that's the cause of this. I am going to get a replacement now. if it works ill let you know
    I replaced the fuse that was fried. And I still have the problem. This is kinda a big deal cause its my daily driver and i cant get it out of park :s.
    someone help please
    Brake lights and shit work. the PNRD3D4 lights are only on if the headlights are on. the bright and turn signal lights work.
    what doesn't work is the gauges, the clock, and the shifter is locked
      which fuse did you replace and where?(engine bay or inside the car)
      -->751 whp @ 27psi <--...Midnight Tuning <----
        I changed the "stop horn" fuse in the engine bay. that im sure had nothing to do with it.
        Where are the fuses at in the car? I didn't even know there was any
          i had a similar problem and for me it was the brake switch, dunno if that might be the problem for you
          Accord MR Thread
          Ek MR Thread
            Where is the brake switch at? how would i check it?
              Someone tell me? I looked under the steering wheel and passenger foot area. I dont see anymore fuses
                it's on the driver side left ,there's an obvious cover ,you can't miss it
                it's right where your left leg would be to the left
                  I found it. Thank you a bunch mr.phil
