hey wats up
    hey wats up
    hey trying to find out witch is better h23 swap or single vtec
    Single cam vtec is not a "swap"
    Its a down grade.
    wat?
      single cam vtec is garbage.
        DOHC all the way bro.
          Save the SOHC. But not the VTAAK one.
            Hmmm all these replys and not even a basic explaination why . . .
            OP:
            Singlecam VTEC = Economy
            Twincam VTEC = Power
            Soch = Normal engine
            Doch = More tunability, hence more power generally
            My 5.7 LS1 Holden Ute
              the soch vtec head flows very poorly. that is why that particular motor is garbage.
                soch you doch !
                wat?
                  Now i may be wrong, or have the wrong F22, but i was following the syntec top shop challenge through super street mag. On the site there are videos for each part of the build and i remember Bisi saying that the head on the F22 is close in comparison to the head on the S200 f20c/f22c as far as its flow rate.
                  Heres the link, im not sure which vid it is...
                  http://www.syntectopshopchallenge.co...eos/index.html
                  90 Accord DX H22/LSD Swap DD
                  01 S2000 Silverstone
                  90 Civic DX K24/K20 ~ Track Whore To Be!
                  ~TeamDOHC.org Join Today~
                  http://teamdohc.org/forums/index.php
                    OP:
                    Nice answer...thanks for the info
                    My Honda
                      Go with the twin cam you wont regret it.
                        The F22 he refers to is the F22A Non Vtec
                          the f22a (the stock motor in all usdm CB accords) head has a fantastic valve angle and port design. with some quality port work, especially on the exhaust side, the f22a head can flow better than most of honda's more performance oriented heads. this has been verified by bisi, as well as a head porter that did hondafan81's head (i forget the name at the moment)
                            Thanks for the explaination Jonas
                              OP:
                              nuff sedd..
