tips on buyin a good engine?
    Well I was lookin through craigslist and found me a H22 for seven hundred (engine, dist, exhaust n intake mani, v-tec solenoid) the guy said that he put the motor on the car and only did 4 oil changes he bought the engine from ebay with low miles 50k, now im not sure if its good or not even tho he said it is, but does anyone know what to look for is there anything that i should look for thatll tell me that the engine is good/bad? i will take the valve cover off and check for burned oil and sludge
    Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
    Is it still in his car? If so do a compression check for sure. Check the plugs. Sparkplugs can tell you a ton of valuable info on the condition of an engine.
    GOT F?
      its off the car he had it on a automatic could i do the compression check out of the car? just crank the pulley with a wrachet
        leak down.
          No you couldn't turn it fast enough.
          You could also try this:
          Take a portable air tank with you, Get a fitting with the same thread as the sparkplug and pump air into each cylinder and see if it leaks out. Its kinda like doin a leakdown test with the head on the car. Just make sure the cylinder your workin on is at TDC.
          But even if it need a rebuild, (rings, bearings, ect.) for 700 bucks your gettin a pretty good deal IMO. Hopefully the head is good. I dont hear of any havin trouble.
          Wed3K beat me to it.
          GOT F?
            the engine is off the car
              yea thats what i said imma take a look at it tomorrow or sat hopefully its all good i dont wanna get too excited but its hard man!!
                yea man 700 bucks is a good deal anyway. i havent seen one for a dime under 950 yet lol
                  you can leak it out of the car.
