Cam install DIY?
    Cam install DIY?
    Is there one of these on here? I've seen something, but it doesn't really give to much info on the process.
    I'm debating on getting a stage 2 bisi over the stage 1, but only if changing the cam is easy enought to swap out for smog once a year.
    HAHHA when are our CB's old enough to be smog exempt??? 10 more years?
    My Honda
    If you havent done so , go grab yourself a Haynes Manual. It it very detailed and shows you the process ste-by-step.
    Good Luck.
