Boosted cb7
    Boosted cb7
    hey guys, i got a 91 accord exr and im swapping the f22 out for the f22 vtec and am adding boost to it and i want to make 300whp, is this possible on a safe tune without having to build the motor? keeping in mind i am using hondata s300 and i also have a spec 3 clutch, comtic headgasket, arp headstuds, manifold with external wastgate, 255lph fuel pump.
    Behind Every Successful Person...Lies a Pack Of Haters!
    you should make good numbers.. remember to get a free flowing exhuast..3in from downpipe to muffler..less restrictions will net you more power. iginition is also a key too.
      is there something wrong with your f22a or do you just have the need to boost a shit motor? the f22b1 is garbage. turbo will make power with it but no more than on an f22a
      300whp is doable if you tune carefully. i would do it on a dyno to be safe. at least the stuff you plan on using are good.
        are u swapping ur f22ax for the f22b1 sohc vtec?
        if so i think this is a bad move, the f22 you have right now is perfect for boost because of its low compression. the f22b1 has higher compression i believe .
        alone in this game . ::My Ride My Way::
          no it has the same 8.8:1 compression. the head just flows like crap.
            http://www.cb7tuner.com/vbb/showthread.php?t=2847
            Boost Lee had a boosted f22b vtec. I didnt follow it thoroughly, so I dont know how things went for him, but I'm sure he's got plenty of info on his build on the link above
            ^^click it or ticket^^
              mine has over 350,000km on it and smokes constantly, the motor i chose was from the 99 accord, the f22a1 vtec, i plan on them tuning it on the dyno, but i dont want to push it to make 300whp..if its going to effect my reliability then i will just shoot for around 250
                the 99 accord should have the f23a1. there were no vtec f22a engines.
                regardless the head flows like crap. you are better off getting a replacement f22a (or f20a). where are you from?
                  my mistake, f23 sounds right, i live up in calgary, also can i use a h22 head?
                    Use f22a head. Its that simple.
                    wat?
                      so eliminate the vtec?
                        just use an f22a. its the best choice.
                        the vtec system in the f23 is on the intake side only. it is for fuel economy not performance. the way the head is designed, the ports are very restrictive. it is crap for performance.
                        the h22 head actually flows less than a modified f22a head. its a better choice as the vtec system is performance oriented... but you seem to be hung up on vtec. honestly, if you use the h22 head on the f22 or f23 block you're going to have a greatly increased chance for reliabilty issues. it doesn't just bolt on there. you have to modify things.
                        the f22a is strong. it has low compression. the valve angle and port design is fantastic. in stock form it works very well with turbo. beef it up, and you can make an insane amount of power with it.
                        get over vtec. if you want turbo, vtec has nothing to offer you. you do not need it.
                          After you slap on the turbo on the f22ax and get a good tune you'll have 200 hp or probably even more. Then you start working on the head and internals and you'll get 350 easily.
                            with good parts and a good tune people have daily driven over 250whp on a stock-block f22a
                              im not really caught up on vtec i just wanted a newer engine and i couldnt find a f22 with lower km on it, so i went with the f23....i had also thought of getting the head port and polished do u think it would be worth it? and also, would it be cheaper to use the f23 or build the f22?....i plan on keeping the car for a long time cause i love cb7's so help point me on the right track i have till wednesday
