1992 Honda Accord LX 5 Speed
    I just got my first accord yesterday!! Aside from general maintainance ie... new plugs, oil, air filter, and so forth, is there anything else that is a problem area with these cars? Maybe preventative maintainance suggestions would help me out. I am also having a hard time finding out what the color is. It reminds me of seafoam green. I want to know what the official honda color is. Most appreciated!!
    PS the car has 218,000 miles.
    congratulations and welcome
    prolly arcadia green
    pics would help
    to achieve a Fuck, you must first give a Fuck
    Follow me on twitter @tru_whitetrash
      fixing the rust should be a top priority.
      Click to see ride.↓↓
        Color
        Any ideas on the color? And what is a good site to order replacement sheet metal and other parts?
          Color is Opal Green Metallic:
          http://www.cb7tuner.com/vbb/showthread.php?t=104001
          TASauto.com is a good site to get replacement rear panels and other parts.
            That cb look likes it belongs in the snowfield lol.
            Another thing you might want to think of doing is a seafoam treatment
            93 ex coupe
            http://www.cb7tuner.com/vbb/showthread.php?t=164698
              new plugs, oil, air filter, and so forth, is there anything else that is a problem area with these cars?>>>
              Fuel filter, P.C. valve, power steering/brake fluids, radiator hoses/heater hoses, timing belt, balance shaft belt, water pump, w/p seal, oil pump seal, valve cover gasket, C.V. axles, oil pan gasket and rear main seal are all items that I would inspect for leaks/condition and replace if I didn't know the vehicle's previous maintenance history...especially the timing belt.
              Look for cracks in the cv axle boots, if they're cracked (but not split open) you can just replace the boots. If you wait or they're already split open, you'll have to replace the axles as the grease leaks out and raod dirt/grime gets inside and chews them up.
              Also check the steering rack & pinion for leaks.
              Common problem areas are with the distributor, Main Fuel Relay, ignition switch, and ignitor.
              In any case, they're typically very reliable cars... especially for their age. You'd be hard pressed to find much else from 90-93 that will get you where you need to go as reliable, economicle, stylish and as trouble free as these cars will (especially beyond 200,000 miles).
              I tend to stay clear of engine additives on the shelf, however, I have consistantly heard and read good reviews on Seafoam and also Auto RX.
              I want to know what the official honda color is. Most appreciated!!>>>
              Opal Green.
              1990 Honda Accord LX coupe
              F22
              116,xxx miles
              1989 Honda Accord LX sedan
              A20
              177,xxx miles
              1992 Cadillac Allante
              4.5L V8
              70,xxx miles
                WOW! lol looks like i have an interesting couple of weeks ahead of me. I know the rack and pinion is ruined it drives like a bulldozer. the person before me stained everything and didnt take very good care of the car. engine sounds good..... but im just a noob so i dont know any better. and thanks guys for the color... i found that thread soon after i posted. oops. also does adding a header and intake affect reliability or gas milage any?
                  header and intake won't really hurt ur gas milage that much. cbs get around 400 miles to a tank pending drving habits and how much city driving u do. sounds like ur thinkin of puttin money into the car. if so start wit the body. being ur engine is in good shape, keep it that way. the accord is notorious for bein reliable. just the body will give up on faster than u think. rust is like cancer for a car. once tested positive for rust its a long road to recovery. cb7s usually rust right around the back quarter of the car as the coner of the rear bumper meets the body. and all around the rear wheel wells. there is def some options some cheap some pricey. pendin how long u plan to have the car should be how much u should plan to put into it to get it right.
                  the rebuild!
                  http://www.cb7tuner.com/vbb/showthre...50#post2073450
                    body work does wonders. Thats what Honda's famous for
                    93 ex coupe
                      lol man
                      keep the opal green metalic yo it is a good colour
                      look on my ride thread for ideas my 92 lx sedan
                      back at it again
                        accord
                        i am def gonna keep the color. I thought it was ugly as hell at first. this is my first body work experience. the left front fender is smashed in a lil bit
                          driverside door jam should tell you the color code.
