i bought a 93 ex a couple weeks back and as far as iv'e seen its supposed to have an f22a6....the owner stated that its the original engine and the code is f22a1?? however the tranny code is h2u5 which supposedly came with the a6...since i know the only difference with the a6 was intake exhaust and what not is it just an f22a1??? i don't know its just wierd or someone lied.
confused about engine??
unless there was a mixup at the honda factory its a replacement engine. f22a6 comes in all 92-93 ex models. unless, of course, you are in canada, or you bought a canadian ex... which is the same as the us lx.
the a6 also had a different cam, different valve springs, and a windage tray. check the ecu. if it's a pt3 then its made for the a1. pt6=a6. it says it on the side of it.
