Turbo on a AUTO
    Turbo on a AUTO
    i know they said theres no stupid questions on this forum, but i was wondering could you run a turbo set-up on a automatic tranny?
    I know you cant run very high boost if you do i would guess the max would be around 4 or 5 psi. But i was wondering if it was possible would the tranny be able to take low boost?
    Possible: Yes.
    Practical: No.
    The tranny wouldnt last too long with that much power.
      h23 trans can handle 300 stock so thats your best bet
      UNDERGROUND SOCIETY
      NEW COUPE MEMBERS RIDE THREAD COMMING SOON
        Auto Tranny No Likie Boost...But with a auto it would be a sleeper!!
        1990 Accord LX Sedan~Sold
        1993 Accord EX Sedan~Sold
        1995 Suzuki GSX-R 750~Totaled
          it can be done but you would have to beef the trans up to handle the boost
          UNDERGROUND SOCIETY
            if u got the money to boost then do a manual swap 2.
            <a href="http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=69766163&a lbumID=2514992&imageID=53057155"><img src="http://hotlink.myspacecdn.com/images02/64/857639fdf04f4f459e4573e823180161/m.jpg" alt="" /></a>
              there was a guy at the Springfield, Va meet last year with a turbo H22 in a coupe with an auto tranny putting down over 300 hp.......
              ...its doable.... but prolly not very practical.
              Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
              ...Zex wet kit, 65 shot, dual purge, JDM H22...pure sex! .....I owned 8 CB7's in one year...top that JARHEAD...lol
              ...this thread has been graced by the new CB7 King
                buy a trans cooler,dont run more then 6psi, and dont gun it at every redlight.you'll be fine.boost lee's car used to be turbo and auto..and look at it now
                spoonsportsaddict
                  [JDMchristian9]buy a trans cooler,dont run more then 6psi, and dont gun it at every redlight.you'll be fine.boost lee's car used to be turbo and auto..and look at it now[/QUOTE]
                  ...and you'll be fine!
                  96 mx-6, needs work...
                  91 accord lx sedan, needs work...
                    If you can build the auto transmission , it's possible.
                    1996 Honda Civic LX 2009-2012
                    2012 Kia Optima LX 2012-2013
                      i'd say that on less than 10psi it would hold up okay, the main problem with automatics and hp is heat, you need a good tranny cooler and it would be a good idea to hook up a temporary tranny temp gauge to make sure that when you're hooking up all that power you aren't straining the f*** out of it. although if you drive like a maniac constantly, yeah nothing is gonna last long.
                        It would be a sleeper but its going to eat your tranny up!!!!!!!
                        I fly by like the coupe grew wings!!!
                        Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        My coupe!!!
                        http://www.cb7tuner.com/vbb/showthread.php?t=152924
                        Originally posted by Racer_XXX
                        Excuse me miss, YOUR FUPA IS IN THE WAY!!!
                          ok Ill bite. There is a member on the forum that is turbo and uses an auto lsd. His set up does over 250 whp maybe 325hp but that is a guess too high. Any who back to the topic. If I were to turbo my auto. I would use the stock radiator cooling. Add a large tranny cooler. Followed by a small electric fan. Also I would keep an eye on the trans temp gauge. Add some type of additive too.
                          Oh and by the way if say at wot your are at 15 psi and red line 6.5K rpm. THe trans will shift and you should craddle at 2.3-3K. I think if you could cut boost at 6k and gradually boost after the shift your car would be ok. THen again that would be too detailed for the average person. The TCU would def have to be tweaked. Im not smart enough for input output code. Any thoughts ?
                            yea. blazinaccord.
                            he went thru engines like crazy tho
                              if u going turbo use a f tranny it holds gears longer
                              You Can Catch me Ridin In My CB Eyes On The Rearview Lookin For The Police
