clear water in radiator
    i have been leaking water from some hose that i already fixed.this morning i checked my radiator coolant and i saw like it was just clear water.should i open the port from the bottom of the radiator and let some out and add 50/50 coolant or should i do a radiator flush and start with fresh. Any advice would help. thanks
    so you just filled it with water? & yeah 50-50 is a good idea
    93 Accord LX Sedan (sold)
      The mix depends on your climate conditions (excuse me for my ignorance on international climates)
      However if you only see clear water, drop the water out of the radiator (remember about 0.5-1.0 litre will stay in the block) and put in a 60-65% mix of coolant to water back into the radiator.
      The 60-65% mix should equalise the amount of straight water left in the block back to 50%.
      My 5.7 LS1 Holden Ute
        I hope your radiatior wont crack from the ice if u just have only water
          when is the last time anything froze in southern california?
          water can cause corrosion though so you want to get it out of there. i say do a full flush to be safe.
            Yeah your right i sure this is my best bet.
              19TcappaLX
              hey guys i been using pure coolant in my radiatior for some time now will that cause problems later now.
