t w coolant temapure sensor
    do you know where the coolant temapure sensoer is ..........................
    There are three of them: two on the upper coolant hose neck that's connected to the engine, and one on the head (I think) a little bit more rearward.
    "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
      theres 3 that I can think of...
      one on the upper/front part of the engine. where the upper radiator hose goes to.
      one just behind the termostat.
      one under the dizzy.
      they each have theyre own perpose
      one tells the ECU the temp
      one tell the gauge the temp
      the 3rd I cant remember
      93 Accord LX Sedan (sold)
        any idea which one this is? i cant find any info on the sensors except just coolant temp/thermo sens
        8 Accords so far:
        '81 SE Sedan(1st Gen), '83 SE Sedan(2nd Gen), '89 SE Sedan(3rd Gen)
        '89 DX Sedan(3rd Gen), '92 LX Coupe(4th Gen), '92 EX Wagon(4th Gen)
        (3rd gen parts car) I'm currently Driving a '14 Accord Sport 9th Gen
          ok thanks... i knew there were one but not three?
            found it...
            ok heres what its like on the OBD2 H22...
            radiator fan switch=one just behind the termostat.
            engine coolant tempature (ECT) sensor=big one under the dizzy.
            engine coolant tempature (ECT) guage sending unit=skinny one (single wire) under the dizzy
            OBD1 F22...
            engine coolant tempature (ECT) switch A=one just behind the termostat.
            engine coolant tempature (ECT) switch B=one on the upper/front part of the engine. where the upper radiator hose goes to.
            + rep would be appreciated
              k cool i was just making sure i replaced the right sensor.. but it still didnt solve my problem of a cold no start..
              http://www.cb7tuner.com/vbb/showthread.php?t=123242
              8 Accords so far:
                which one would keep the fan running after the car is off
                my cb7s radiator fan will run after the car is off and even when the car is cool ill turn the switich to on and and not even start it a it will start the fans
                than once i come back to the car the relay is buzing
                i herd it could be one on the these 3 sensors but which one would it be and where
                ''It is what it is, Do what you want''
                http://www.cb7tuner.com/vbb/showthread.php?t=167905
                  Make sure that your connectors are correclty plugged. the sensor under the dizzy should have a grey connector and the other two have green connectors
                    Sounds like the cooling fan timer relay, its right next to your main relay above the drivers side foot well fuse box. The relay has "fan timer" or something like that written on it.
                      and the sensor responsible for that one would be on the upper rad neck on the head.
