Cb7 Maintenance question
    I love to baby my car and I have done the most basic of things, oil change, motor flushed, coolant flushed, tranny flushed, new valve cover gasket, plugs and wires.
    I was wondering what else I could do. I was thinking about the timing belt, anyone else's ideas?
    A jack of all trades.. An ace of none.
    There are two kinds of people in this world... H22 swappers and F22 builders
    Fuel filter & Valve adjustment
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      EGR clean, EGR port clean, FIV Clean.
        Cap and rotor
          Don't forget an air cleaner as well, that can really boost fuel economy (especially combined with the other things you did. A fuel system cleaning can be quite beneficial too (can be done professionally at places like Firestone, Jiffy-Lube, etc.).
            I realize you're referring to the drivetrain, but def. go over the body for rust, the car is nothing w/o a solid chassis
              I assume it's a inline filter?
                I got a new air filter, I have also done a fuel injection cleaning service. A cleaning agent thru the PCV valve line and a intank. Thanks though.
                  this is the first thing I do to every Honda I buy...
                  o/f change
                  transmission flush
                  brake flush
                  coolant flush
                  air filter
                  fuel filter
                  pcv valve
                  spark plugs
                  cap & rotor
                  valve adjustment
                  timing belt & balancer belt
                  drive belts
                  waterpump
                  fuel system & top engine cleaning
                  and obviously any necessary repairs/services, i.e. brake pads, fluid leaks, broken parts etc.
                  00 Jeep Grand Cherokee 4.7 V8 4X4
                  92 Honda Accord LX
                  95 Honda Civic CX
                    it's mounted on the firewall below the black box.
                      seafoam before crankcase flush!
                      Originally posted by wed3k
                      i rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
                        A valve adjustment can make a world of difference. And make sure you're timing is set correctly.
                        ~Built not Bought~
                        --member ride page--
                        http://www.cb7tuner.com/vbb/showthread.php?t=130234
                          I would check all the ball joints on the car. I checked mine, and replaced it, mechanic told me the thing could have pop out anytime after a bump.
