Valve Cover Gaskets
    Valve Cover Gaskets
    One of the bolts holding the valve cover down was broken, I replaced the gaskets with it and I couldn't figure out where the little o-ring type ones went. I didn't see any like that when I took the old ones off. Where do I put them?
    Picture of what Im talking about.
    http://la.gg/upl/VS50365R.jpg
    Lower tube seals I'm pretty sure. Those take more work to change, so if you don't want to tear into the engine anymore to do it, then just don't worry about them.
      Yep, those are the lower tube seals, you have to remove the rocker arm assembly to gain access to those.
      Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
        Thanks guys
          Do you have any oil on your spark plugs when you change them? If you do, then you want to replace those rings.
          ~Built not Bought~
          --member ride page--
          http://www.cb7tuner.com/vbb/showthread.php?t=130234
