alot of people gave me different ideas so i wanted to hear more. thanx!!
i want to lose some weight out of my 93 2-door what would be the best things to do?
<a href="http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=69766163&a lbumID=2514992&imageID=53057155"><img src="http://hotlink.myspacecdn.com/images02/64/857639fdf04f4f459e4573e823180161/m.jpg" alt="" /></a>Tags: None
There's thread all about this here. That pretty much goes over all of the stuff you can do. In the end tho it really depends on how far you want to go.Originally posted by 92dmI was actually just being a smart ass, and not really contributing to this at all.
Bought from: cb95spd
Originally posted by JDMchristian991 View Postit doesn't matter.you could take everything out of a cb exept a drivers seat and they're still heavy as shit.Originally posted by deevergote.And please, for the love of God, type like a human being!
Originally posted by garreth8tsu View Posti wish mine wz 2000lbs
You will probably need some aftermarket parts, a carbon fiber hood, lexan, a light seat, some light wheels, and a small battery.
You will need to completely strip the car, remove all sound deadening, cut off all brackets that were holding the parts you removed, remove the rear bumper support, gut the front bumper, get a header and put a light cherrybomb muffler right after the collector, either get a carbon fiber trunk or gut the stock trunk, cut out the trunk bottom(it actually weighs A LOT) and weld some thin sheet metal in there, ditch the center beam and stock crossmember and make your own unit, ditch the dashboard, ditch any wiring you dont need, ditch the stereo, A/C and heater, remove the sunroof if you have an EX, cut/gut all doors besides the drivers door and weld them to the body, get a Civic radiator from a junkyard, remove anything that isnt necessary under the hood, make an aluminum intake manifold, get an 8lbs flywheel, ditch the wipers, you can also do a little more cutting inside and in the engine bay without affecting anything..... all this should definitely bring you down to ~2000lbs
I think it would be cool. Or you could just buy an 89 Civic hatchback and it is already 2000lbs lol
i should jus ride a bike but wow that is alot of things i can get rid of<a href="http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=69766163&a lbumID=2514992&imageID=53057155"><img src="http://hotlink.myspacecdn.com/images02/64/857639fdf04f4f459e4573e823180161/m.jpg" alt="" /></a>
Originally posted by 91 EX-R View PostWhat about kentucky accord's car? He got it under or at least right around the 2000 lb. mark.
Originally posted by wed3k View Posthe cut sheet metal out though, it aint practical.
It WAS probably pretty unsafe though.Originally posted by deevergote.And please, for the love of God, type like a human being!
Originally posted by 91 EX-R View PostOh, I know. Just saying that he got that car down to the same weight as a Civic.
Originally posted by wed3k View Postim cutting the door panel sheet metal out too but it is to make room for the cage. so im adding integrity att he expense of weight.
And kind of getting off topic, but what's the status on your project car?Originally posted by deevergote.And please, for the love of God, type like a human being!
