I looked but i didn't find any info on the possibility of stroking our stock engines the cheap junkyard style. I was thinking in the lines of getting an f23 crank and guessing f23 rods. any ideas?
stroking the f22a
the f23 rods are thinner too. and i would think it would lower redline due to the geometerty of the f22 as it is people stroke the h22 but it is already a shorter stroke than a f22 i would think to destroke the f22 would be cool and use a f20 crank and let it be rev happy and the f23 jornals are 55mm as your f22 is 50 or something like that so it won't work anyways
The F22 and H23 have the longest stroke. To put in any other crank other than a custom billet or something you would be destroking the motor. If your wanting to get more out of it look more into incresing compression and valvetrain and camshaft grinds.
There is a lot more to stroking a motor than just pulling the old crank, replacing it with a new one and calling it good. There is machine work involved and clearances that HAVE to be precise. Doesn't really seem as if your ready for in depth motor work. Just keep reading and soaking in info. Ask questions so you understand.
For everyone here is a spec out of the F22 motors:
F22A This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar. Specifications Bore × Stroke: 85.0 × 95.0 mm Displacement: 2156 cc Valve Configuration: SOHC, 16 valves, Non vtec Compression ratio: 8.8:1 Max power: F22A1: 125 hp (93 kW) @ 5200 rpm F22A4: 130 hp (97 kW) @ 5200 rpm F22A6: 140 hp (104 kW) @ 5600 rpm F22A7: 150 hp (110 kW) @ 5900 rpm (147hp/108kW with automatic transmission) Max torque: F22A1: 137 ft·lbf (186 N m) @ 4000 rpm F22A4: 142 ft·lbf (193 N m) @ 4000 rpm F22A6: 142 ft·lbf (193 N m) @ 4500 rpm F22A7: 145 ft·lbf (198 N m) @ 5000 rpm"you can catch me swoopin 4G coupin switchin lanes" haha haha.
1993 SE coupe drag car ahoy!
1992 EX coupe 5 spd **sold **
Did work for: jhoff_cb7
thanks guys I see what you mean I forgot the H22 has a shorter stroke and Bigger bore and basically there is no crank that just bolts up using the same main and crank bearings. Anyway i did see that Race Engineering sells pistons for the f22 that use std. 85mm bore I think that's the route i'm going to take with my bottom end and also crower rods. i really wanted to stroke the vehicle but in cheap way but i guess there really isn't a cheap way
Originally posted by pz3rd View Postthanks guys I see what you mean I forgot the H22 has a shorter stroke and Bigger bore and basically there is no crank that just bolts up using the same main and crank bearings. Anyway i did see that Race Engineering sells pistons for the f22 that use std. 85mm bore I think that's the route i'm going to take with my bottom end and also crower rods. i really wanted to stroke the vehicle but in cheap way but i guess there really isn't a cheap way
Originally posted by WiKKeDV16 View Postdont even know if this combo would work.. havent looked up specs but.. lets see who finds out if it will or wont
h22a4 usdm block (55mm mains)
f23a crank(55mm mains)
f22a rods
88mm CP slugs
h22a head
should be fun(that is if it can be put together) lol
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
Just remember that even though your throwing the std bore pistons back in you still need to hone the cyls to make sure your rings seal correctly. There is ALWAYS machine work needed when rebuildign/refreshing a motor.
Bump your comp ratio to around 9.5 or 10:1 and have your head proted and intake mani ported and add new valves and check the rest of your valvetrain then add a cm gear (adj of course) and change all seals and belts and you should have a stout F22a."you can catch me swoopin 4G coupin switchin lanes" haha haha.
Originally posted by JDMCB3Si View PostThere is ALWAYS machine work needed when rebuildign/refreshing a motor..
Oh and Carlos. I know someone that will more than likely do the frank you posted.
