how do i change h22 tranny fluid ?
    if it requires a change , then i want to do it
    its a manual so shouldn't it be similar to changing engine oil
    also what tranny fluid do i use and filter ?
    -1992 CB7 EX w/H22 [sold 10/09]
    -2005 Legacy GT limited [current]
    umm ya its basically the same except theres no filter. u need a 17mm wrench and i would suggest royal purple tranny fluid.
      Honda MTF
      3 CB's gone....
      1 WK Overland....
      Still miss the CB though......maybe one day.
        gm synchromesh is good too
        theres a drain plug. 17mm or maybe even a 3/8 socket hole that you put your ratchet directly into. i forget. you refill from the top. need a funnel with a long hose on it to do it. no dipstick. it takes like 1.8 quarts or something. a little under 2
          does auto zone or advance have the honda mtf, if not where do i get it ?
            dealer
            92ex coupe h22
            93 240sx with silvia front end (kadet in the works)
            http://www.cb7tuner.com/vbb/showthre...=1#post1894990
              whats the excact measurement on how much to add when you change the tranny fluide.drain and fill.i use ATF tranny from dealer
                ATF doesn't work so well in a 5spd.
                wat?
                  how about AUTO
                    how about AUTO
                    ATF is Automatic Transmission Fluid
                    Not being a ass but just making it clear for anyone else. That's all.
                    So to answer you question. ATF would would great in an auto tranny.
                    3 CB's gone....
                    1 WK Overland....
                      what i do is raise the left side, while draining the oil. then when its done, lower left side. raise right side. then refill. thats how i do it, get it all out. easier to fill also.
                        Ok, so exactly how much fluid for the 5speed H tranny?
                        VTEC DUDE!!!!!!!
                          its damn near right at 2 quarts. If not its like 1.9. I lift the right side when filling and all 2 quarts goes in. Go with honda MTF from the dealer. It's like 6 bucks a quart
                            yes you are right.
                            1.9-2.0 quarts it is.
                            www.PreludePower.com
                            BB SQUAD MEMBER #28 V.2
                              jonas, you are retarded. It is a hole only for a 3/8'' drive ratchet. Then the 17mm above that is the fill hole.
                              I have seen people fill through the vent hole, vehicle speed sensor, and even take off the shift linkage to fill it up.
                              Gary A.K.A. Carter
                              [sig killed by photobucket]
