Oil Leak?
    Oil Leak?
    What is the best way to track down an oil leak. I was warming my car up this morning and I went out and there was a little puddle. Seemed like alot but wasn't too much. So I drove it around for fifteen minutes parked it and let it sit. Came back in another half an hour and there was only a tiny drop. What is the best way to track down a leak? What usually goes that needs replacing?
    Thanks,
    JTM
    Check the crank seal and rear main seal they usually go bad on high mileage.
      Thanks,
      JTM
      I steam cleam cleaned and de-greased the hell out of engine bay and underbody, then drove it for a while. It showed where all the "new" oil leaks was and i attacked it. Mine was the valve cover gasket near the distributer. No problems after that...
      http://www.cb7tuner.com/vbb/showthread.php?t=116662
        if you have a ex, the oil cooler adapter ring could be bad, but if thats leaking, its easy to find, cuz it drips RIGHT on the down pipe, and smokes
        you'll love my nuts!
          maybe your bolt or gasket
            2x, i just replaced that gasket on an A6 on tuesday for a former coworker of mine. it actually wasn't that hard to replace just make sure you have a 30mm socket to remove that plug with.
              First thing to do is ask what work you have done recently on the car, then think whether the leak could be related to that.
              Second, slip some cardboard under the car and let it sit. See where it leaks, then jack the car up on jackstands safely and take a look underneath with a strong flashlight. Bring rubber gloves and lots of rags.
              Take it from there.
              Once you have a sense what side of the car it's from, whether it's engine oil or tranny fluid or power steering fluid or whatever, we can proceed further.
              In general, strong candidates are a loose oil drain plug or washer (or stripped), the drain pan gasket, or (more of a drag), seals under the timing belt cover. YOu could also have a leaky oil filter or oil pressure sending unit.
              But really, you need to localize the leak first, then fo from there and try to trace it back to the source.
              Post back with more info and I'm sure someone can help further.
              Also, fill the oil up and mark down the date and odometer reading. Check the level again at intervals to get a sense of how much oil you are losing. If it loses a lot more oil on a long drive than when it's sitting a comparable time parked after driving, then it could be seals around the crankshaft oo balance shaft or camshaft, or valve cover gasket, which only would leak during running, and would leave an oil trail down the road that you wouldn't notice because you're in the car driving while it's leaking. If it's a more or less constant leak, whether parked or driving, then I would look at the drain plug and drain pan gaskets. because those are more likely to leak even when the car is parked. The drain pan gasket less so than the drain pan bolt.
              good luck.
                I would take it to those DIY carwash places they have and pay the 1.25 for the pressure washer and just go to town cleaning everything in the engine bay and under the car. Be sure to cover up all the electronic stuff like the dizzy and dont spray in the spark plug holes lol, Oh and also cover the intake filter w/ a bag or something to prevent that from getting wet.
                If you still can't find it, at least you'll have a clean engine bay in 5 min. or less
                member's ride thread
                91 Accord SE 176k
                  Take it from there.
                  good luck.
                  Very informative thank you! The valve cover gasket and tube seals were recently done. However I noticed the leak before that. I got under the car today and the bolt was fine and the oil filter was too. The pan gasket looks to be in good shape (not deteriorated etc.). There is oil all over but not like dripping. So I had difficulty doing much. I might have to bring it somewhere where I can actually get under it real good.
                    where is that located?? Any pictures?
                    91-accord
                    watch quick clip: 10-80 mph
                      Allways Start From the Top and Work Your Way Down!!
                      1990 Accord LX Sedan~Sold
                      1993 Accord EX Sedan~Sold
                      1995 Suzuki GSX-R 750~Totaled
                        i have a huge oil leak now on my 93 ex and it seems to be coming from where the trannsmission and engine meet. any ideas?
                        yes im 15, yes my car and i are the same age, and not now but soon i will smoke you
                          Thanks,
                          JTM
                          first off degrease your engine then drive it around let it sit and then track the leak back to the source
                          but it might be-oil pan gasket or oil drain bolt washer
                          -oil pressure sending unit leaking
                          -cylinder head covers leaking
                          -engine oil seals leaking.
                          your having the same problem i did.. i track the lake back to my oil pan and found out the threads in the pan itself was worn so try those and let me know
                          BREATHonda
