Hey i kno every one has does this. Shifting gears without using your clutch. Now my question is does this make any harm to ur car?
Shifting without using clutch.
Theres really no reason to do it anyway, unless your lazy.
Using the clutch pedal is faster, smoother, and theres less risk of causing damage.
My 5.7 LS1 Holden Ute
Originally posted by sunburn View PostI can do it pretty well , But I drove a truck for 7 years . I belive the trick is to get your rpm's high enough then quikly shift (but dont force it ). I also belive it is alot easier on a large truck transmission due to the lack of syncros in them .90 Panda DX F22A6
er, synchros are not for shifting without the clutch. they're for when your shifting. They spin the gear whiles you move the shifter in so that you don't grind with the clutch in. Back in the day everyone had to rev match even with the clutch in.
http://en.wikipedia.org/wiki/Manual_...d_transmission
Just so you know what life would be without synchros
