Knockin Noise
    Knockin Noise
    I was driving down the freeway sunday then all the sudden my engine starting loosins power.....pull up in a macdonalds and the engine started knocking real bad and like squeeling.... i thinkg the oil pump went out...... what you all think?... get a new motor?.... change the oil pump???
    CB7_HULK SMASH!!!
    sounds like your have a bearing about to go out completly, i would change the oil pump and check the bearings before it gets worse.
      sorry but im not that good with internals.... whats a bearing? where is it at?
      CB7_HULK SMASH!!!
        your rod bearings, are located in your oil pan, jack the car up , drain oil, remove pan, take each rod cap off and check the bearings one by one, do not mix them up.
          ooo the things that hold the rod and the piston in the crankshaft?.... what should i look for?
          CB7_HULK SMASH!!!
            yea, look at the wear pattern and see what color they are, if they are copper color then they are going bad, of if both bearings are melted together then its deff bad and if that happens you need to polish the crank or get another.
              how much would all that parts run? sorry i know i ask to many questions but i suck at internals.... i can get an used engine for 300 dollars. i really want a h22 but i dont know how much i can get it for
              CB7_HULK SMASH!!!
                rod bearings are $35.99, and oil pump is $168.99, ( at autozone), plus labor unless your going to do it, but if you know the condition of the other motor, and its good, then i would just buy that, cuz you may need to get the crank polished but you never know till tear down.
                  if he is knocking then he is going to need a rebuild, the other motor is the cost effective way to go
                    thank you dude ... ima go check out the motor... its almost the same thing.... maybe i just buy that motor and keep the old one and just build it u know
                    CB7_HULK SMASH!!!
                      that will be a learning experience
                        it sure will but man money is short i just paid 500 on tickets.... i got in an accident like 2 months ago and got more tickets so now i need 720 for tickets.. so yeah im fucked when it comes to money... i miss my lil hulk my job's service truck its slow
                        CB7_HULK SMASH!!!
                          "good things come to those who wait"
                            yeah im making plans right now on how to manage my money
                            CB7_HULK SMASH!!!
                              If the knock is loud like you say, then you wont have to dissasemble the rod caps to check for wear, you will for sure be able to just jiggle the whole rod back and forth on the crank. I say just go with a whole engine then save and build the h22.
                              GOT F?
