p12 ecu
    p12 ecu
    i installed a p12 in my 92lx and now my car gets stuck in gears
    I have no idea what that means.
    wat?
      Do you have a 5 speed or an automatic? If it's an auto, check the plugs for your tcu. If it's a five speed, I can't imagine that it's related to the ECU.
        That's what I was going to say, I wouldn't think the ecu would have anything to do with the gears, either way.
          I don't have any experience with the auto, but since the xCUs are next to each other, the only thing I can think is something happened during the swap. Maybe the plugs wiggled out or one of the wires popped out of the harness.
            The ECU shouldn't have any effect on the TCU...
            However, just in case... did the P12 come from an automatic or manual Prelude?
            I assume your car is automatic... as this makes no sense if it's manual.
              My car seemed like it shifted slightly higher and harder after my P12 install. No idea why. Mine is a 93 auto. It shifts fine, though. I THINK my ECU is from a manual. (Don't quote me on that, I'll have to check.)
              It's possible that there's a malfunctioning TPS circuit on the ECU, and that'd have a slight effect on the shift points of the TCU. The detent (kickdown) cable has the most influence, but shift points/firmness are also determined electronically.
              MRT(vvv) --Stock CB7 Enthusiast #1--
              Vouches: new_beginnings, ThrakBarts, beanzfynest617, JaK FRoSTWhiTE, 92_EX_Ninja, mak
              i am with the dumb. i cannot brain.
                I wonder if the Prelude shift points are different... the Prelude S TCU might be something to consider as well!
                Sucks I haven't had an F22A1 in my car for nearly 6 years now... it doesn't really apply to me.
                  Well i have been running my 93 auto for a while now with -12 and have not had this problem. So I suggest pulling the ecu/tcu fuse, and checking the install one more time.
                    like the car stutters its auto and the check engine light stays on
                      Sounds like an electrical issue, unfortunately. Make sure all the connections are there/snug, and if everything looks good, you might have a bad ECU on your hands, though I hope not.
                        what codes? pls check them before you pull it might help in future diagnostics
                        96 Accord SiR driveline installed. CF2 donar
                          a little off topic but
                          what year preludes have the p12 ecu?
                          PSN: DJ-dlatino
                          My ride
                          http://www.cb7tuner.com/vbb/showthread.php?t=140370
                            92-95 prelude SINGLE CAM (f22)
                            Just do what PR CB7 said.
                              mine would redline about 200 rpm higher then it did with the pt3.and it shifter a little harder as well.but it shifted fine after the install..pull codes.
                              spoonsportsaddict
