I was wanderin if any h22a, h22a1, h22a4 throttle body is bigger than the f23a1 throttle body? if so whats the difference? Ive done the research and they look like the will fit...... any help will greatly appreciated
Throttle body
Originally posted by Rooter View PostI was wanderin if any h22a, h22a1, h22a4 throttle body is bigger than the f23a1 throttle body? if so whats the difference? Ive done the research and they look like the will fit...... any help will greatly appreciatedLast edited by AbsurdNY; 11-20-2008, 06:34 AM.
i know for a fact that he does cause he is my cuzin
my ride check it out
http://www.cb7tuner.com/vbb/showthread.php?t=122926
an if u have myspace add me
http://profile.myspace.com/index.cfm...ndID=138825010
Originally posted by AbsurdNY View PostI'm pretty sure that no H series throttle body will fit on a F series manifold. The studs are spaced out different. Someone correct me if I'm wrong. I'm not too familiar with a F23A1 manifold but I'm pretty sure its probably the same as a F22A6 manifold. You probably would not get no benefit in performance without changing the whole manifold. If the F23A1 is the same as the F22A6, keep the runners, get a H22/23 upper plenum and throttle body and you would benefit the most.
Originally posted by Supaman View Postim almost positive that u can take an F23A1 manifold and put it on a F22A6. Theres a thread on here somewhere(cant remember where) that recommends that manifold to get a lil more power, along with a list of other parts, deevergote made it.
