If you use this ESP mount on the F22A swap, you wont need to weld the tranny bracket to the car or shim the drivers side,, right
ESP Bracket
Originally posted by tootall View PostIf you use this ESP mount on the F22A swap, you wont need to weld the tranny bracket to the car or shim the drivers side,, rightMaple50175 - you're annoying =P
Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
JoshM - Crotch rocket = chick magnet.
I dont know which tranny i have but i do have the bracket mount for the manual tranny and one stud is there now and where the other studs would be are already threaded to fit where the manual bracket goes..
havent ordered yet ,but probably just the one mountLast edited by evil_demon_01; 02-11-2009, 03:18 AM.
Originally posted by tootall View PostI dont know which tranny i have but i do have the bracket mount for the manual tranny and one stud is there now and where the other studs would be are already threaded to fit where the manual bracket goes..
far left mount is the normal 5 speed mount
far left is the auto to 5 speed mount
WHen you order the mount specify your doing an auto to manual swap and so on. The sets they sell are different.
Why would they make a mount to fit just the ex models and why would the ex , lx make different mounting points on there trannys..
thanks for the help. appreciate it, getting all the knowledge i need befor the engine actually gets pulled, ready to pull any day..
what about plugging the holes for the coolant to the auto trannyLast edited by evil_demon_01; 02-11-2009, 03:18 AM.
you just put a plug on the radiator line.
and the bracket is made so that you can use an h22 or h23 tranny. it will only work on the ex f22 trannys, beacuse they have provisions to make the stud pattern the same as the h series tranny. just read in there members ride page or contact john. he is very helpfulMaple50175 - you're annoying =P
