okay so i got my motor all put back together thinking i fixed the noise. and i started last night. and the noise is still there. it sounds like a valve is lose and ratling around. could this happen. Or does anyone have any other ideas of what it could possible be.
h22 noise in the head what could ity be
Red Wagon DD - 1993 EX
http://www.cb7tuner.com/vbb/showthread.php?t=172734
Gray Wagon Project - 1992 LX
http://www.cb7tuner.com/vbb/showthread.php?t=166337Tags: None
yea, my valves still tick a little even though i just adjusted my valve lash, its just how hondas are i guess, my 'lude did it too. if you dont feel like buying a valve adjustment tool you can make one by welding a 5/8" box wrench to a 10mm deep socket. just dont adjust em too tight and burn a valve dude. just my 2 cents
thanks i now its suppse to tick a little but its bad
when it drives too
i havent adjusted them yet. cant find anyone to help me.
I would start with a valve adjustment
here is a DIY, but the pictures aren't there.
http://www.honda-tech.com/zerothread?id=618786
Sorry, maybe somebody knows a link with pics
thanks
i figure i should ask my question too since my car makes that noise sometimes too....only at idle when i give it gas up to like 2k then let it idle again, it makes that sound like a rocker is loose but it doesnt do it as bad or as often as it use to...i guess its going away
could that be the auto tensioner or something else?
F20B CB7!!
ive heard that could be it. thats how mine started then it got worse. i did to the timing belt on my h
