I just had T-belt job done recently and since then I always get a loud screeching/squeaking noise upon startup. I assume it was one of the belts and upon inspection noticed that both p/s adjuster bolts were loose.
So (without looking at the procedure in the FSM.......which states to loosen that special nut right underneath the p/s pulley) I went ahead and tighten both tensioner bolts. I guess I applied too much torque cuz I snapped off the right side bolt (I think that was the 10mm one).
But I noticed that the smaller bolt is there only to hold that bracket in place. And then both bolts go through the bracket into the threads.
Is an e-z out drill/tap my only option here? I will appreciate any tips.
