How to install adj coilovers ?????
    i jus bought sum adjustable coilovers and need sum tipz on putttin dem on ive done it once a while back to a civic i had but still wont mind some extra knowledge
    I would suggest renting a set of spring compressors from kragen for your stock springs, then when your putting in the coil overs make sure you cut down the bump stops on the struts. I would recomend getting some KYB struts to go with the coil overs just because they are designed more to handle adjustable coil overs instead of regular oem springs. After everything is all finished up make sure you get an allignment, also an adjustable camber kit would help as well. Lemme know how it goes
      werd good looks
        What are you talking about? Full coilovers, or crap coilover sleeves?
        If they're full REAL coilovers, you just replace the old assembly with the new one. It's straightforward. Unbolt the old, bolt on the new.
        If you're using cheap coilover sleeves (hopefully not on stock shocks ) then yes... you just use a spring compressor to compress the spring so you don't die. Then usiing an allen key, hold the strut piston steady while you undo the nut. Pull the top part off of the old assembly, put it on the new strut with the coilovers (facing the right way). Be sure to cut your bumpstop in half.
          LOL sorry i stereotyped the question based on the E-Thug ebonics, no offense 2drcb7. Didnt think Full coilovers were the case
            Yeah, I did the same... I TRY to give people more credit, though...
            I'm willing to bet that your assumption is correct. Your advice is also spot-on.
              LoL thanks deev i have a few suspension repuilds under my belt so i figured i would speak up.
