h22a swap
    h22a swap
    im thinking of getting a h22 for my 91 juss wondering any info of where to find everything i need and an estimate of around how much i will spend
    try the sticky threads in the swaps section. they tell you everything
      Just link to the thread if you're going to take the time to tell them where to look. It takes you 5 seconds longer, and it might actually encourage someone on here to develop a brain!
      http://www.cb7tuner.com/vbb/showthread.php?t=5423
        sorry its right there not like i just said search
        anyway so i can add to the thread and not get yelled at again
        the cost depends on where you get the motor and how much you do to it. you can do an h22 swap for 1000 or it can cost you 4x that much.
          http://www.hmotorsonline.com/shop/sc...age&item=30016
          You are local so you could pick it up.
          My swap thread
          Main relay proplems?--DIY
            thanx i looked up the engine and it goes for 750 but i cant seem to find the ecu
              hmotorsonline.
                thanx alot man
                  HMotorsonline.com
                  Got this JDM H22A with LSD Tranny, ECU, TCU, all sensors, wiring harness, and Type-S valve cover for $2095! Check out HMotorsonline.com. I picked this up at their spot with a trailer. They have the cleanest, most reliable engines I've seen. Pretty much all of the SOCAL CB7 cats got their swaps from there.
                  If imitation is the best form of flattery............thanks for kissing my ass.
                    How the hell did you get it so cheap, Gerald? Mine was $2400 shipped, and I didn't get LSD!
                    Of course, that was nearly 6 years ago now...
                      My boy Craig knows Steve up there and he hooked it up!
                        Werd!
                        Man... if you talk to Steve again... tell him I never got my paperwork! "I'll send you everything you need to prove your motor is legit, so if the cops try to fuck with you, you can show it to em"... never got it. Or my shop threw it out (that's more likely, actually... those guys were morons... I'm still fixing their mistakes!)
                          Be carefull where you buy it. If the price is that cheap, you'll want to get it compression and leak down tested before you buy. Hmotors does it to all engines before they sell it to you. Also, 750 is just for the engine without the tranny, which isn't really that good of a deal anyways.
                          Hmotors is now charging less too, and if you pick it up you don't pay shipping and handling.
                          "H22A 92-95 Motor, Tranny, Computer
                          Price: $ 1899.00 Plus shipping and handling.
                          Availability: In stock and ready to go."
                          Ofcource, that's without LSD.
                          My swap thread
                            Oh yeah, that's right... I got the "full swap"...
                            I have a shelf full of stuff I'll never use in my basement... axles, wires, etc...
                              Hmotorsonline has a lot of reputation and all, but you'll pay like a bugger for it.
                              You can pretty easily find h22s with all sensors and the ecu for a grand, as well as h22 non lsd trannies for 500. You'll have to do a little bit of searching on google for local engine importers, but it's often worth the money saved.
                              On the flip side, Hmotors does have the reputation that most of the small importers can't match.
