Any time I've had or heard of the relay goin down It's spark and fuel, never just one or the other.
Accord problems
Can you hear the fuel pump making noise in the trunk when you turn the ignition on?
Originally posted by EXR-ALB View PostAny time I've had or heard of the relay goin down It's spark and fuel, never just one or the other.Last edited by AbsurdNY; 11-10-2008, 02:16 AM.
The main relay activates the fuel pump. That's it.
An overheated car will not cause the solder points to crack. The main relay is about 6" in front of your left knee while driving. If the interior of your car is getting hot enough to melt solder, you have more problems than a main relay to worry about!
Main relays go bad. They're old. The solder points crack, and sometimes you can't even see it. Resolder the relay, or replace it. Even if it's not the problem, it'll be fixing one potential problem later on.
If the car overheated, check to make sure you don't have any head gasket damage. Coolant in your cylinders could cause starting problems... or worse, hydrolock.
