h22 knock sensor..
    h22 knock sensor..
    i have a h22a automatic in my 93 coupe . i did the swap everythingz fine just wanted to ask i didnt wire up the h22 knock sensor .. will this be needed for vtec to work ?? i changed out vtec solenoid and vtec oil pressure for new units . and had joser from crzytuning wire up the vtec solenoid and pressure switch .
    No, you don't need the knock sensor for vtec to work, but you check engine light won't shut off until you wire it up, or chip the ecu to eliminate the knock sensor.
      thanx bro ... another question can i get a p28 to work with automatic tranny or do i need another ecu ??
        The H22's have the Butterfly's in the intake manifold. So a P28 will not run that even if you get it chipped. (Which you'll have to do anyway). Unless you go with a different intake manifold or a spacer where the butterflys are on the stock intake. But I don't have any experience with P28 running auto's...
        91 Accord Ex
        97 Civic Ex
        91 Crx B16
          actually, if you talk to joser he can help with that. you don't need the butterfly's to run through the ECU. just have him plug it to straight vacuum so they will stay open. thats what we had to do to mine.
            thanx bro i didnt kno that . ima talk to joser . but wat ecu can i chip and still run my automatic h22 tranny.
