Ok, car has been running fine after the swap couple months back. New problem now is the vibration while at high speeds. Between the speeds 65-90 mph, i get crazy vibrations like the steering wheel wants to fall off. if i keep it steady at 65 mph, i can feel the vibration from my right hand to my left hand with both hands on the wheel. Anybody got any idea what can be causing this. I have new axles. 2 sets of wheels and vibrates on both sets. Replaced ES bushings. Balljoints not yet done. I hate not being able to run my car at highway speeds. Any suggestions guys?
Front end vibration help!!!
I got the same problem lol.
but have you checked the balance of the front wheels? or had them checked to see if they are bent?
93 Accord LX Sedan (sold)
I had a very similar problem recently with my civic. The steering wheel would vibrate side to side quite a bit. got my wheels balanced and guess what? no more vibs.
Now, it could be a few other things in your case...
Front rotors
axles
wheel bearings
could also be some loose front suspension bits. best thing to do to check for front suspension play is jack the front of your car, and in a 12:00 and 6:00 position move the wheel back and forth (with lugs fully tightend). If you have play while doing this inspect your ball joints and find out which one ha play.
next put your hands in the 9:00 and 3:00 position and rock back and forth. there might be a bit of movement here from the steering wheel, that's normal. but other play in this area is not. If you have play here inspect the tierods.
i work for a large franchied shop that does free inspections for brakes and other small stuff. get a shop to put it up and do an inspection a good look is worth the safety and piece of mind. if you got someone to shake a wheel so you can look for play, don't be afraid of a large screwdriver to pry a little to check play
good luck96 Accord SiR driveline installed. CF2 donar
i have a set of 18 inch Racing harts just got new tires mounted and balance. i even put my stock set on last last week to see if it was the wheels. Still was shakin. Checked for play of balljoints last week. No play.Everything seems to be tight with suspensions and bushings. Ties rod needs replacing. I justhave the boot cover on it. I try to do everything myself but i might have to get this inspected and looked at. Does not feel nice to me going on the highway.
No, i have not gotten an alignment yet. I was gonna wait and replace my control arm balljoints first. Think an alignment will fix the vibrations? My car is not pulling to either side. i wonder if firestone still have the lifetime alignment my friend was telling me about. As much as i tear this car down, that would be great.
where i live discount tire offers a lifetime one for like $60. i think that might help ya. just cuz its not pulling doesnt mean its aligned. im pretty sure bad alignment can cause vibration as well.91 ex sedan
And now, new for 2012, a 93 ex wagon!
Paypal verified
Bought from: frootloops, 90accords, Agol
sold to: Agol
Originally posted by sdhardcoregamer View Postwhere i live discount tire offers a lifetime one for like $60. i think that might help ya. just cuz its not pulling doesnt mean its aligned. im pretty sure bad alignment can cause vibration as well.
